Salta al contenuto principale
L'Apple Watch Series 1 è una revisione dell'Apple Watch originale ed è stato annunciato il 7 settembre 2016. La maggior parte dei componenti è la stessa del Series 2
123 Domande Visualizza tutte
Apple iWatch face reseal
Glass came off of Apple Watch 42 mm need to reseal glass to watch.
Questa è una buona domanda?
Punteggio 0
2 Commenti
The battery is ok. My daughter somehow opened the glass by trying to charge it when I first gave it to her. The watch is working normally except for the glass top not sealed to base.
da
And how do you know the battery is OK? If it lifted while it was on charge it sounds to me like the battery expanded and pushed open the screen. Did you remove the screen and visually inspect the battery?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
its best to have it done professionally, it could be that the battery has expanded and made the screen lift and if u try to force it back down it could break the screen. also the force touch sensor is almost like a little gasket in between the lcd and frame and its easy to damage
Punteggio 3
Aggiungi la tua risposta
fgsamm sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 311
