Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
iPhone 6 won't turn on but charge
Hey,
I tried to fix this iPhone 6 but it here is what it already checked for:
  1. It’s not turning on at all
  2. No charging sound when plugged in
  3. The device charges as it takes 0.5amps from the charger
  4. I already checked the battery it’s fine
I thought a change of the Tristar IC would fix it but I guess due to the symptoms, this won’t be the case. What else can I check for or try?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
What is the history of the device; was it dropped, repaired or came into contact with water prior to this failure? Is the phone charged with a cheap dollar-store charger or an Apple original or MFi certified charger?
If you’ve already ruled out the battery, then consider trying a replacement Lightning port. However, with the symptoms it shows, I would suspect a logic board issue, which will require a micro-soldering repair.
Punteggio 1
1 Commento:
@refectio cant say lot about its history. There is no water damage as far as I can say that neither was it repaired before. Bad charger could be. Any ideas on what to test for/replace on the Logicboard? Sure it needs microsoldering.
da
Aggiungi la tua risposta
andruchs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 74
