Salta al contenuto principale
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
103 Domande Visualizza tutte
Why is my screen has a high contrast even when turning it down?
I just saved this old mac from being thrown into the garbage by my college surplus store and fixed it up. However, every time I boot it up, it has a whitish screen and then I have to put it to sleep for a few minutes and it will look fine. Is there an issue with the lcd or video card?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sadly your logic board has a problem. I suspect one or more of the caps or solder joints in the GPU logic has degraded so it needs a bit of time to warm up to work.
Your logic board has the GPU chip mounted onto the main logic board it doesn’t have the MXM GPU daughter board design.
I would leave things alone and live with it. If you really want to fix this it will take someone with good board level diagnostic skills.
Punteggio 2
Aggiungi la tua risposta
Bau Pham sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 34
