Put iPhone 7 battery in iPhone 6
Did someone know the dimensions of an IPhone 7 battery or is it possible to put an iPhone 7 battery into an iPhone 6?
Questa è una buona domanda?
It’s not the dimensions that make the difference , it’s the connector. The connectors for iPhone 6 and iPhone 7 battery are totally different. The wattage/hour is also different. They are not compatible each other.
The connectors for iPhone 6 and iPhone 7 battery are totally different => Are you sure ? Ok than i can’t use an iPhone 7 battery.
Yes, I can confirm that the connectors are physically different between 6 and 7 because I charge all my replacement batteries externally with a battery test board fixture.
When you’ll say connectors, is that the charger port it self are something internal
The battery connectors are different. Not the charging port dock connector.
Can I put an iPhone 7 battery into an iPhone 6 device ?
iphone 7 battery fits the 6s but you have to bend the cable slightly as the iphone 7 battery has a longer lead
Ultime 24 Ore: 4
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 91
Tutti i Tempi: 14,511
