Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1623 Domande Visualizza tutte
Replaced Battery not recognized
Just replaced my battery with a battery purchased from ifixit. However, my computer doesn’t seem to be recognizing the battery. From system report and coconut battery it shows that no battery are installed. I’ve tried all the troubleshooting methods like NVRAM /PRAM reset, SMC reset, repair disk permission but nothing has worked so far. It’s not the charger’s issue since a green light appears when plugged in. As well switching back to the old original battery, my computer recognizes it and shows that a battery is installed. What else can i try? Is it the battery’s issue then?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If I understand things the original battery does work when you reconnected it (seen in CoconutBattery)
Then you have a bad battery and you’ll need to get it replaced. The shipping paperwork will have what you need to do to get an exchange.
Punteggio 1
Aggiungi la tua risposta
johnsonxin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 43
