Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Why does my iPhone shut down (as in run out of battery) after 5 minute
Lately I have been getting a multitude of problems which includes:
Unresponsive screens
IPhone Dying after 5 minutes of being idle (much less battery life if in use - Has to be connected to a source of Power to function on a basic level)
Randomly types unwanted letters at random times
Heats up extremely easily
etc…
I would like some help for at least one, if not all, of this is possible.
Thank’s for your time
Questa è una buona domanda?
Punteggio 0
1 Commento
Do you use a Mac Or PC with ti?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Your battery is most likely at the end of its life. To be certain, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). Anything less than 70% of design capacity will require replacement.
 Based on your description, you may also have a screen issue. However, I would start by replacing the battery first and see if that solves the shutdown issue. Then if that is solved but you still have Touch issues, then you’ll want to consider changing the screen.
Punteggio 2
Aggiungi la tua risposta
Yoake sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 44
