How to get my stripped battery screw out?
Hello, I have a mid 2010 MacBook unibody. The battery on it was bad. It would work when I plugged the charger in, but one day I noticed the computer was wobbly and the casing was popping off. I opened it up and noticed the battery had expanded. Thank God it didn't explode. I ordered a new one online and it came with the necessary screw drivers to remove it. When I began to uninstall the battery, I stripped the last screw I needed to remove to get the battery out. It was a triwing screw. I researched how to remove the screws and have found answers saying to use a Dremel, cut a slot and then use a flat head. I am very uncomfortable doing that as I have unsteady hands and the screw is right near the logic board where you disconnect the battery and it's the side where the battery began expanding. I tried to see if pliers would work. I thought if I was able to get a grip around the head, I might be able to turn it, but because the screw is too small and I can't seem to get a grip. I've tried larger drivers, different drivers, pliers, just to try and get some kind of grip, Nothing worked so far (obviously) I don't know what else to do. I thought about a computer repair shop but I cannot even get to one right now. Any help on how to get this thing out without harming my logic board (or my life lol) would be appreciated. Thank you!
Questa è una buona domanda?
