Salta al contenuto principale
The Canon EOS Rebel T3i, released in March 2011, can be identified by its SKU (SKU:5169BO32). Also known as the EOS 600D and the EOS Kiss X5, this camera is a Canon Digital SLR with 18 megapixels.
20 Domande Visualizza tutte
error message "card's write protect switch is set to lock"
when turning on the camera with memory card inserted, i got this message
"card's write protect switch is set to lock" although the card is not lock, tried different card and samething. when i took the card out, it reconized there’s no card and reinsert again, the message come out.
cant take no with push on the shutter button
Questa è una buona domanda?
Punteggio 2
1 Commento
Have you found the solution? I have just incurred the same issue
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi!
Can you make sure that your card is indeed not write protected? Check the position of the switch on the card:
https://i.ytimg.com/vi/1YPSfvaZceI/maxre...
Punteggio 1
Aggiungi la tua risposta
simonleongkm sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 957
