Salta al contenuto principale
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
76 Domande Visualizza tutte
just tone and no boot after Mac mini mid 2010 16GB upgrade
After installing the upgrade the mac is just generating a tone every 4-5 second and does not boot. I saw on the guide page that at least 2 other users had the same problem. Anybody has an idea of what to do?
Thanks
Frederic
Update (09/25/2018)
I am running high sierra on that mac but, with only 2GB, it is struggling, hence the temptative upgrade…
Questa è una buona domanda?
Punteggio 0
Commenti:
Aggiungi un commento
Kit di riparazione per Android
Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
Acquista ora
Acquista ora
2 Risposte
Risposta Più Utile
Do you still have the original RAM (in working order)? If so, try plugging the original RAM in and see if this behavior continues.
A beep every 5 seconds typically means bad, incorrect or no RAM.
Punteggio 1
Commenti:
that is the first thing I tried. when I put back the original ram, it boots without problem. then I put back the 16GB and it went back to beeping. If it means no ram or bad ram could that be that I received bad RAM?
da
@freblewski Try @danj 's solution, then if that is a no-go you have probably received bad RAM. Comment below mentioning me if Dan's solution does not work.
da
In order to run 16 GB you’ll need to be running OS-X Lion 10.7.5 or higher and make sure you’ve updated with the latest EFI firmware. The highest this system will run is macOS High Sierra 10.13.6
If you’ve not updated to El Capitan OS-X 10.11.x or newer you’ll either need to do that first or manually install the newer EFI firmware from here: About EFI and SMC firmware updates for Intel-based Mac computers
Punteggio 0
Aggiungi la tua risposta
frederic reblewski sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 163
