Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
iPhone 7 Front Camera not working even after sensor replacement
My iPhones’ front camera is not working. Ordered a new sensor unit and just plugged that in instead of the original one without installing it (earpiece connect etc.) but the camera still refuses to work. Already tried to unplug the back camera. What can cause the issue? Is the logic board dead?
Thanks for answering!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
After the flex replacement all as same that there might be the problems in connector or other component near connector damage or open.Check it clearly you find solution on.
Punteggio 0
1 Commento:
The connector is fine. Have even cleaned it with alcohol.
da
Aggiungi la tua risposta
Leon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 61
