Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
iPhone doesn't wake up from standby
Hey, my iPhone 6 doesn’t wake up when it’s on standby. If I press the home button or standby button the backlight is enabled but the screen stays black. I forced a hard reset by using dfu-mode and tried different batteries and displays, but it still stays the same.
Do you have any additional ideas?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Does your display ever work, like when you boot it from a shutdown; or is it always showing the backlight but no image when it should be “on”?
Try connecting it to 3uTools (for Windows) when the display isn’t working to see if the phone is fully (or still) booted. If 3uTools sees the phone, then you probably have a LCD driver issue. This requires a micro-soldering repair.
Punteggio 1
1 Commento:
Yes when I boot it it shows me an image. Everything is fine then. I turn it into standby and after 5 minutes or so it won't wake up.
da
Most likely it is a broken LCD. The backlight turning on with no image means that the connections between the cable and the LCD at the top of the screen under the front camera flex has been broken. This can be fixed by replacing the screen
Punteggio 0
1 Commento:
I tried 4 displays. Problem stays.
da
Aggiungi la tua risposta
elreparero sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 249
