Salta al contenuto principale
The first generation Nvidia Shield Tablet released in July 2014. This device is often used for gaming, and has Wi-Fi and LTE capabilities.
24 Domande Visualizza tutte
Half of the screen is black
Screen has no *serious* physical damage (no cracks), but half of it is black. Touch screen works (including the black part of the screen).
What’s the problem and how to fix it?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @icecom ,
Has the tablet been dropped or gotten wet at all?
Connect an external monitor to the tablet's mini HDMI port to check if it shows a full display.
If it shows a full display then you have either got a video flex cable problem, a video flex cable connection problem or a LCD display panel problem.
If the external monitor's display also shows only a half screen display, then you have a GPU/motherboard problem in the tablet.
Here’s a link to the ifixit Nvidia Shield Tablet Repair guide which may be of some help in opening the tablet so that the video flex cable/connector can be inspected if you have determined that it is not the GPU that is the problem.
Punteggio 2
Aggiungi la tua risposta
Aleksey Timofeev sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 49
Tutti i Tempi: 3,217
