Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
I get No Service Message with SIM installed?
Got an unlocked IPhone and placed SIM into slot. Read the card temporarily and then I reset network and No Service again.. Should I get a new Sim Card??
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Unfortunately, this can mean a few things. But! Here are some suggestions and things to try to save the trip to your carrier or a whole loop of going back and forth.
  1. Make sure the SIM Tray is properly seated and is fully slotted in. If there is resistance or it is not fully seated, there may be debris in the port.
  2. Check inside the slot carefully, see if there is any debris lodged in there as it can be keeping the SIM from being recognized. Carefully remove debris.
  3. Clean the SIM Card. First off, I would inspect it. Any noticeable discoloration or damage would indicate that you will need a new SIM, but a small smudge or a piece of debris can be removed! Taking a soft, non abrasive cloth and cleaning the SIM gently.
  4. Update the iPhone to latest iOS Release. Sometimes all you need is an update to correct any faults.
Hope this helped! Good Luck!
Punteggio 0
Aggiungi la tua risposta
teach0697 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 28
