My lg 50uh5530 wont power up. Red light flashes three times.
My lg 50uh5530 wont come on. No sound, no picture, and the red light blinks three times. Read many Q and A's to discover that this problem can be multiple components from the power supply board to the main board and even the led strips in some cases. I've tried unplugging the unit for 24hrs twice with no luck. I have removed the back cover to visually inspect for damaged capacitors or loose connections and found nothing. There is a faint ticking sound coming from the bottom corner of the power supply board near the capacitors. I also checked the 12 power pins with my meter and I do have a 3.5v standby reading but instead of getting 13.2v for the middle pins I get 6.5 to 7.0v. Looking for further advice to make sure I dont waste money. I'm prepared to replace the caps, the entire power supply board, main board, or any other component to fix the issue. Just dont want to buy an exspensive part like others have done when it may be something simple
Questa è una buona domanda?
14 Commenti
Checked the led strip pins and got no voltage with the connector in or out. All capacitors look fine.
da James Walker
I have the same tv mine started today ! I will never ever buy another LG product ever .. Junk !!!
da edweeks3
Just happened to me today. Oh well.
da Todd Carnes
Was this resolved with oldturkey03's solution? Just want to know if I should dive into this
da Eric Benroth`
My just did the same thing. It's a lg50uk6090pua.
da Radioace318
Mostra altri 9 commenti
