Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Replacement Screen has blue tint and not as bright/vibrant
As the title says, I have replaced my screen on my iPhone 6. Originally I was replacing the flex antenna behind the logic board. While following the instructions on the guid, I lifted the screen like a hinge and it cracked in the top right corner. With my grumbles aside, I ordered a replacement screen which I was able to replace with ease.
The problem however is that even on max brightness, the screen is not that bright. Everything appears to have taken on a blueish tint and when comparing with coworkers its easy to see the blue difference. I have taken apart the device to confirm the cable as sat properly. Is there something I’m missing? Or is this an exchange about to happen?
Questa è una buona domanda?
Punteggio 1
1 Commento
When you go to https://www.ifixit.com/Store/iPhone/iPho... which is the main landing page for iPhone 6 parts. The display I purchased is listed as the second item. The 'used' displays do not show up until the second page.
No where on the listing iPhone 6 Screen does iFixit state that the quality of this product is subpar to the 'used'. In fact it actually says "and increasing the quality of your repair."
On the 'used' listing, there is a selection to the ABC quality (best, ok, worn).
iPhone 6 Used Screen
It looks like I will be contacting support and hope that my replacement doesn't have the blue tint.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Please contact iFixit support. We are just volunteers helping people fix their stuff.
However, one thing you could do is to re-install the original screen to be certain that there is a colour difference. Keep in mind also that iFixit sells three quality levels of screens:
  • The regular aftermarket screens (less expensive but may have a different colour profile)
  • Used screens (original quality but may have some cosmetic imperfections)
  • Their “Choice” line which is a OEM quality screen that may have some aftermarket flexes or front glass.
They each have their advantages so you have to pick your poison, so to speak. You can read more about iFixit Quality here.
Punteggio 1
2 Commenti:
Hello,
I was hoping there was an installation issue. I actually reinstalled the original screen to confirm that I wasn’t going insane.
iPhone 6 Screen
At the time of purchasing, I don’t remember there being a quality selection option.
I guess I will go ahead and contact customer support.
da
Yeah, you have to go through the entire parts lineup to see all the options. You may want to make that suggestion to the support team, they're pretty responsive.
da
I had a strong blue tint at a start in the middle of the day, with a very reduced total brightness. I had a screen replacement too, but only the glass and a while ago. Playing around with the color filters in the disabilities settings ngs, I get the tint to a more neutral setting, but not totally white, maybe by a lack of patience. The nightshift setting works even better, it’s a bit more pink then what the filters achieve, but brighter to start with.
Thinking back, I believe I had some light effects even beforr dropping the 6 plus phone fom the loft.
Iwould rather suspect the sensors burned by over use, bright sun or constant use than an intervention concerning the glass. Or a software issue.
If anyone has a good solution, I would be grateful.
Punteggio 1
1 Commento:
This worked really well! I chose Color Tint and what looks like about 25-30% Intensity and the Hue pretty far to the left till it looked better to me. The brightness issue was fixed by this too.
da
Aggiungi la tua risposta
Albert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 62
Tutti i Tempi: 26,108
