I found the following on another website.
Not sure if this is the exact same problem buy may be worth trying if you haven't yet.
I hope this helps!
Part 1: Fix Boot Loop by resetting your device
In most cases, iPhone reboot loop can be solved by resetting your iPhone. First of all, you can reboot your device into recovery mode. Doing that would link your device directly with your iTunes account and then you can restore a fresh iOS version to your iPhone and recover all the iTunes data, too. The detailed steps are shown as below:
- Once stuck on Apple logo, turn off your iPhone.
- Connect your iPhone to your PC, then keep pressing and holding the home button until your iPhone goes past the Apple logo.
- When you enter the recovery mode, you'll see your iPhone's icon appears on your PC and there is one option for you to reset your device. Just tap on the "Restore iPhone" icon.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
