Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2686 Domande Visualizza tutte
6s Water Damage 9 Volt On c2300
Hi Guys..
I have an iphone 6s Water Damage.
After Ultrasonic bath, i try to on it, the DCPS draw current between 0.01mA - 0.08mA or 9.
All VCC main voltage are regular.
I find only 9 volt on c2300 if i plugged battery and usb, only on one side.
Without battery connect one side the voltage is 4 other side also 4.
I try to change this capacitor but the problem is same.
I already change tristar and Tigris.
Anybody help me plz.
Questa è una buona domanda?
Punteggio 0
5 Commenti
is the current draw before prompt to boot or after
da
@tech_ni Thanks Daniel. The current draw only after power on..
da
did you check vbat
da
Yes Daniel.. Vbat is 4 Volt..
da
did you check l2300 area
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
That is normal behaviour for C2300. It is part of the Tigris buck converter circuitry and when the phone is charging, you will see 9V on the IC side and ~4.2V on the coil side.
You need to continue your troubleshooting by checking the output voltage rails from the PMIC and the BBPMU to see if there are any shorts.
Punteggio 2
1 Commento:
Thanks @refectio :))
da
Aggiungi la tua risposta
AGS sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 374
