Salta al contenuto principale
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
229 Domande Visualizza tutte
Lightning replacement - one speaker is mute
Guys, I just swapped lightning flex cable im my iPad mini 1. It was tricky, but I somehow succeed, except one speaker is totally not working. I tried to fix it but no luck, I don't find what's wrong and what MAY BE wrong at all.
So, please, can you provide me with PINOUT SCHEME of lightning flex cable? I have found this datacheet
https://datasheetgadget.wordpress.com/20...
But where exactly is the Lightning here? I suspect it's ALISON-A0-OTPXX (page 81) but it's hard to understand where are the speakers pinouts. Can you help reading the scheme and determining it please?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
ALISON is the Power Management IC (PMIC) and doesn’t have anything to do with the speaker outputs (other than power the speaker amplifier IC).
What you need to look for is J5700. That is the connector for the Lightning port and speakers.
Punteggio 2
Commenti:
Wow... How much ignorant I am in schematics despite I do many repairs for myself! :\ (shame on me)
Many thanks, that's exactly what I needed :)
da
Live and learn...every day! :>).
da
Sorry, one more question! In regards of orientation - do I get right that the first pin is on the side closer to the edge of device and the 32nd is closer to the battery? It's logical to decide so because it's shown in the same orientation as on the MB main drawing but I want to be sure
da
I believe 1 is closest to the battery and 32 is closest to the case edge. Normally, the pinout follows the orientation of the way the connector is placed on the schematic.
da
In this case, PIN 1 is the top-left pad, viewed from the same orientation as my image. The left hand column is odd number and the right hand column is even numbered.
Like this:
3
---4
5
---6
etc.
Logic doesn't always apply to connector or IC orientation because sometimes a different orientation will make the traces easier to route. When in doubt, look and probe for GND pins and determine orientation that way. Or if you have access to a tool like ZXW, it will show you where Pin 1 is.
da
Mostra 1 altro commento
Aggiungi la tua risposta
Anri sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 76
