I have battery problem
Hello!
I have water damaged MacBook pro (a little). When it happened, I was flip over my laptop immediately and take it to some repair center. I've waited for 3 days. Fortunately, my MacBook is alive! Everything is fine. But laptop can't work with the battery. I saw a login screen, then my laptop shut down. But it working fine without battery (only AC).
However, I don’t have time anymore, I took it back. I want to order a new battery and replace it later. I worked 1 day, and my laptop was fine with AC. But today my laptop shut down randomly (3 times). Here are my questions:
- SMC reset will be helpful? Maybe the battery is fine (i'm not sure, water was in touch bar area). May I plug in the battery and do reset SMC?
- While I'm waiting for a new battery, may I reset SMC without the battery?
- Laptop work with battery a few seconds. Is it mean charging circuit troubles?
P.S. Sorry for my English)
Questa è una buona domanda?
4 Commenti
Run this app on your system: CoconutBattery take a snapshot of the main window and post it here for us to see Aggiungere immagini ad una domanda
da Dan
I can't do that with connected battery. I do not have time to run this app, because a laptop will shut down after 5-10 sec. With AC adapter I have no information about battery
da Evgeny
With the system powered by the MagSafe are you able to get it to run at all? Longer that a few secs, hopefully minutes or hours?
da Dan
No. MacBook has the same behavior with MagSafe AC or without it (if battery connected)
da Evgeny
