Salta al contenuto principale
A1708 / EMC 3164 — Lanciato a giugno 2017, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED.
563 Domande Visualizza tutte
I can't connect to an external display using a USB-C to HDMI adapter
I am unable to use an external display using either a MOSHI USB-C to HDMI (4K 60) or Insignia adapter.
So far I have tried:
  • Resetting NVRAM
  • Resetting SMC
  • Reinstalling system software MacOS High Sierra
  • Different adapters (MOSHI and Insignia)
  • Different HDMI cables that work with my older MacBook Pro and external display
  • Different displays
Questa è una buona domanda?
Punteggio 0
1 Commento:
What is the USB-C cable you are using? Some are not for data only power! As an example the cable you get with your system is a power cable for the power adapter.
da
Aggiungi un commento
1 Risposta
Some hub/adapters are just finicky and refuse to work no matter what.
Some hub/adapters will work after Macbook will first go to sleep with the hub/adapter plugged in, enabling the video output on waking up. If you disconnect such a hub/adapter from the Mac you will most probably need to repeat aforementioned procedure again.
And some hub/adapters will just work no matter what, including the one made by Apple itself.
Punteggio 0
Aggiungi la tua risposta
r.escallon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 68
