Salta al contenuto principale
The Nokia 6555 is a narrow black flip phone with a 1.3MP camera.
5 Domande Visualizza tutte
When I speak into the phone, person on other end of call can't hear me
I’ve inserted my original sim card into a replacement Nokia 6555b phone. The numbers all come up and I’m able to send and receive texts. I can place a call to another person and I can hear that person very well; however, the person on the other end of the line cannot hear me even though I’m speaking into the phone. Volume is set to 10 (max) and still other person cannot hear me. What’s the problem and can it be easily repaired? Everything else about the phone appears to work properly.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I found this on Nokia 6120, I hope is helps. https://answers.microsoft.com/en-us/mobi...
Punteggio 0
1 Commento:
If you can be heard when you are using the microphone attached to the earphones but not when you are just using the phone, it points the problem being a faulty or loose internal microphone. Also try using a plugged in headset, also a Bluetooth headset and see if you can hear with them, if so them you may have a bad phone speaker or connection
da
Aggiungi la tua risposta
midgejohnson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 915
