Salta al contenuto principale
Dell 19" LCD Monitor, charcoal gray in color, released in 2004.
8 Domande Visualizza tutte
Have a white screen on power up
Moniter was on and all of a sudden went white. Now it is always white no matter what I do. Is it a motherboard issue or something else?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
White screens are usually indicative of a bad hard drive or corrupted boot system.
Punteggio 2
mrbruce300  on your monitor this just means that only your backlight is on. You will have to check the video source and see if it is connected etc. If the monitor does not show a menu etc. on startup when disconnected from a video source you most likely have a bad main board.
These monitor had issues with bad caps, so you will have to take a look at the boards and check for an obvious damage. Post some images of the boards with your question so that we can see what you see. Aggiungere immagini ad una domanda
Here are the disassembly instructions disassembly.pdf
Punteggio 2
Aggiungi la tua risposta
mrbruce300 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 82
