Salta al contenuto principale
Il Galaxy S7 Edge è la variante schermo curvo del telefono top del 2016 di Samsung, il Galaxy S7. Annunciato a febbraio 2016 e lanciato l'11 marzo. Modello SM-G935.
369 Domande Visualizza tutte
Loudspeaker hissing and "snow" noise
Repaired a customer’s S7 Edge screen and the loud speaker stopped working. Customer brought phone back when the new part came in and I noticed when it was dropped off that the loudspeaker was making a hissing noise and sounded like snow on a TV. After replacing loudspeaker, the problem did not go away. I had a spare S7 Edge at the shop (as all it does is bootloop), took the loud speaker out of it, and tried the 3rd speaker with customer’s phone- same problem.
Everywhere I look, the answer seems to be software/app related. I looked at the board, and compared it to other boards. No signs of a burn or short or missing chip/bent prong, etc.
So, to recap, his original speaker stopped working after screen replacement. He took the phone with him until parts came in. When he brought it back, the loudspeaker was making a hissing noise. Replaced loudspeaker with new part- still hissing. Tried another part from a different source- same problem.
Any suggestions?
Thanks in advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hello,
The only cause I can see is either a software problem, then maybe a factory reset could help, or a component from the motherboard that is causing this problem.
I hope it helped you a bit
Punteggio 0
Aggiungi la tua risposta
Trevor Brodie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 293
