Salta al contenuto principale
Lanciato da Samsung a marzo 2016. Modello SM-G930.
424 Domande Visualizza tutte
S7 won't boot: fixed blue LED and blinking green LED
Hi, my S7 had some battery related problem, and in the past some times failed to recognise the real battery level.
Now I have substituted my old battery with a new one and I have the problem explained in the title. When I push the "power on" button, the S7 vibrates and a fixed blue LED + a blinking green LED show up for some seconds, then "menu" and "return" buttons light up and finally all lights disappear and the screen remains black.
The combination "Power button + volume down" gives the same result, and the combination "Power button + home + volume up" gives no result.
If I connect it to a power cord, after some seconds a fixed red LED shows up, then in some minutes it becomes green. Nothing appears on screen and pushing *any* button result in a freeze from which I can exit only disconnecting the battery, during this freeze the phone heats up.
I think the smartphone is failing again in the measuring of the battery level, since it is behaving like the battery is empty. Any idea about how to solve this?
Questa è una buona domanda?
Punteggio 0
1 Commento
bro, did fix your phone? my S7 undergoing a same problem >.<
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
when you get to ‘and finally all lights disappear and the screen remains black. ‘ do the menu and return LEDs light up when you press the lock button?
Sounds like either screen not plugged in properly or got damaged when opening up the phone.
Punteggio 2
1 Commento:
Thanks for the answer.
I have noticed that some time the smartphone acts like the screen is disconnected: it also rings if I dial my number from another phone.
But the connector is intact and well secured on its socket... Moreover, it still does not acts properly when connected to the power cord: the red led lights up after too many seconds, and in some cases the smartphone also froze with a fixed blue led.
da
Aggiungi la tua risposta
Alessandro sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,670
