Salta al contenuto principale
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
301 Domande Visualizza tutte
Bootcamp on External Hard Drive (can I use it on other computers)
So I have this external Bootcamp that is a portable Windows, however, I fear that the installed drivers on it would not work on other computers, thus making it not boot on other computers that is meant for Windows.
Is there a way to avoid this issue, at least to passby the login stage?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Batterie per PC portatili
Una soluzione semplice per un grande aumento di potenza.
Acquista ora
Acquista ora
1 Risposta
Risposta Più Utile
A proper BootCamp install on the drive requires MacOS. So when you boot up under it using the MacOS partition you can upgrade the MacOS as you normally do for either updates and/or upgrades. The MacOS upgrade or install will update the needed drivers. Nothing to fear here.
Punteggio 1
Aggiungi la tua risposta
rwalmond sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 21
