Salta al contenuto principale
Repair information for the Garmin Vivoactive HR smartwatch. Released in February of 2016. Model number: 010-01605-03.
Won't respond or charge
My watch was on low. attery amdnstopped responding, time is stuck at 5:09, non of the buttons work, I cant turn it off. The screen lights up when I press button but won't turn off. When plus into charger nothing happens. Please help:)
Questa è una buona domanda?
Punteggio 2
1 Commento:
Let Try this
push the two buttons at the same time about 15 second.
The screen will light up again & will back to normal work.
Good luck.
Adisorn T
da
Aggiungi un commento
2 Risposte
Try removing the battery for 30 sec and replacing the battery. This should reset your watch.
Punteggio 0
Plug into the charging cable and power source, then hold power button for 5 seconds. This will enter forced test mode. Scroll through the screens and check your device statistics.
Punteggio 0
Aggiungi la tua risposta
Gina marie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 6,840
