Salta al contenuto principale
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Domande Visualizza tutte
How can I install OS X on a hdd and than use it in a MAC?
So i want to “pre-install” OS X El Capitan 10.11 on a HDD ( with the help of a virtual running OS X on virtual box over a windows PC)
And than plug that HDD over a caddy into my macbook EMC 2254 and hope i can install os x or boot or anything..
WHY am I doing this?
Because only my cd/dvd connection is working and my HDD is completely erased theres just nothing on there ...
BTW i tried booting over USB (yes i did it right with TransMac), but i found out that it can only bolt over optical cd/dvd or a firewire connection
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Why dont you try installing the OS through means of internet recovery? https://www.google.com/search?q=internet...
Punteggio 0
3 Commenti:
I tried cmd + alt + r but nothing is showing up
My hdd is disconnected because the cables are not working and it s been COMPLETELY ERASED
I could buy a caddy and connect hd over cd/dvd connector but unless im 100% sure its gonna work i dont wanna spend any more...
da
When you say the cables are not working are you referring to the sata cable?
da
Yes, there are 2 cables. One thin flex cable and one somewhat bigger ans stronger cable on top of it.
da
Aggiungi la tua risposta
Nenadbrateu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 51
