Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1015 Domande Visualizza tutte
Is this a failing GPU?
Please check the photo below.
If so, this kind of fault seems rare on those Retina 13-inch 2015.
I tried to plug an external monitor, and it shows plain grey, nothing else on screen.
Would that be solved by reballing?
How can I go about this?
Questa è una buona domanda?
Punteggio 0
Commenti:
A1502 never fails for Video. This issue is a screen issue. If the external monitor shows plain grey could be that is asking for the password or your thunderbolt id dirty.
in case your logic board is defective could be a filter communicating pch with screen or just water damaged. take it to someone that can do a quick check.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Yes, your logic board has died. Sadly, your system does not have dual GPU’s. The Intel CPU has it incorporated within it.
Time for a new logic board sorry ;-{
Here's the IFIXIT guide you’ll need to follow: MacBook Pro 13" Retina Display Early 2015 Logic Board Replacement within the guide you’ll find the possible replacement logic boards.
Punteggio 1
if you get it reballed would it work? how does it fail?
Punteggio 0
Same here today. After 1-2 Minutes the Display of my A1502 shows only cryptic artefacts. Could reballing of GPU will fix this problem?
Punteggio 0
Commenti:
This is a RAM issue it can be fixed.
da
Aggiungi la tua risposta
Alex222 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 49
Tutti i Tempi: 2,779
