Salta al contenuto principale
Il controller wireless Xbox 7MN-0001, prodotto da Microsoft Corporation, è il controller più utilizzato per la console di gioco Xbox e può essere utilizzato anche su PC.
Stick drift persists after adjusting the sticks
Hey guys! I've been having bad upwards stickdrift on my right stick, so I took it apart and adjusted it to nearly completely remove it. It was fine. A bit of tiny downwards drift, but barely noticeable. Not long after, the drift has returned. I going to have to rip it apart and asjust sever times a day, or am I just doing it wrong?
Questa è una buona domanda?
Punteggio 0
2 Commenti
Which model is it?
da
Sorry, I should have specified. 1708. The white one.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
You can try cleaning the stick with 99.5% isopropyl alcohol, this has helped me with the same issue in the past, just dab it in with a Q-tip, and clean.
Punteggio 1
5 Commenti:
That was the first thing I tried. Before I tore it completely apart to adjust it.
I'm also getting double inputs on YouTube and Xbox dashboard of that helps.
da
Hm. Hard to tell, with the double inputs, did you by chance get the controller wet? or spill anything on it?
da
No, not that I know of. The double inputs seem to be linked to the control stick though. Whenever I adjust it to remove the drift, the double inputs go away, but they return as soon as the drift does
da
Could it be the sensor that I've been adjusting? If I put a new one in there, might it work normally?
da
A new sensor might fix the issue, however, be careful with the soldering. If there is damage to the logic board of the controller, it will persist.
da
The way plenty of people fix stick drift (including myself) includes the following.
  • Cotton Bud
  • Rubbing Alcohol
  • Controller
  • Wet the cotton bud w/ the RA then tighten it up/ squeeze the end, reapply RA then rub it all around the joystick as hard as possible
Punteggio 0
1 Commento:
what the heck is a RA?
da
I just fixed this on my elite controller and the way i fixed it was by separating the up and down green piece a little. Hard to explain but after you get your controller apart there are 2 green pieces. One for up and down the other for left and right. My conclusions is that the piece is worn out so it's loose. Separate the green piece on the right just a little bit so the black prong on the side go in a little. This worked for me and nobody told me about it
Punteggio 0
1 Commento:
Can you use the lens cleaning wipes because it says it contains isopropyl alcohol so can I use that
da
Aggiungi la tua risposta
Mark Whittaker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 7,435
