Does not turn on unless plugged in
Can not turn on phone unless it is plugged in wall
Questa è una buona domanda?
It has to be some problem with the battery. is it holding charge while is plugged in the wall?
Yes it is holding the charge. But will not turn on unless it is plugged in outlet
I would recommend you to get a new battery,Unless you phone has water damage. If that is the case it might be some issue with the logic board.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 29
