Salta al contenuto principale
Repair manuals and information for the Microsoft Surface Laptops.
103 Domande Visualizza tutte
WD Elements SE 1TB doesn't show up on Surface Pro 3 laptop
The USB drive in the Surface Pro 3 laptop is functioning properly. So as the WD Elements portable as I checked from my Window desktop pc, all the files are there.
Only the laptop fails to detect the WD Elements.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
You’ll need to check power draw of your drive and what the Surface laptop is offering up. To do this you’ll need this great little tool! USB Mini Voltmeter Using it you can plug it into your other system in series with your drive and do the same on your surface let us know what you find.
Immagine USB Mini Voltmeter
Prodotto
USB Mini Voltmeter
$9.99
Punteggio 1
Aggiungi la tua risposta
nina.uk22 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 168
