Salta al contenuto principale
Una macchina da caffè programmabile di Keurig. Questa macchina da caffè utilizza K-Cup Pods e K-Carafe Pods per preparare una varietà di bevande calde e fredde. Numero di modello: K2.0-400 Numero di serie: 401.0200.1410931
Cannot close cover, how do it fix it?
I opened it to insert a Kcup and now it won’t close. How can I fix it?
Questa è una buona domanda?
Punteggio 11
1 Commento
Thanks, I can make coffee now. There has to be a better permanent fix. Maybe replace a part?
da
Aggiungi un commento
5 Risposte
Risposta più utile
I am not sure if this is the exact model, but try this I found on YouTube:
Workaround: https://www.youtube.com/watch?v=Lenlr8zA...
Fix: https://www.youtube.com/watch?v=0Mg43v6v...
Punteggio 2
1 Commento:
The workaround works great. The actual fix is too complicated for me. Lol! At least I can still use it. Thank you!
da
We were able to lift up on the cover and push down on a  black plate and it closed until we ordered a new one.   I am still searching for a repair because it was one of the better Keurig’s
Punteggio 1
2 Commenti:
I have the same problem and also found that pushing the bottom plate down allows me to close the Machine
da
What part did you order .? I can’t seem to see what the problem is although pushing the lower plate down allows it to work I cannot figure what needs the fix obviously the unit is old enough that trying to have it repaired simply isn’t worth it
da
My kcup Is off-track how do I fix it
Punteggio 0
can not get the lid to close keurig 2.0
Punteggio 0
How to close the lid
Punteggio 0
Aggiungi la tua risposta
Katherine Harrington sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 23
Tutti i Tempi: 20,381
