If you just don't care if it can get worse you can try to dissasemble the metal frame from the screen, not from the laptop but the screen itself.
First you can, with some care, try to press all around then edges of the screen.
If you are more desperate in some screens (I never did it on a Mac) you can clean the rubber that makes the contact between the glass and the board, but you need to completly dissasemble the screen.
What happens is that most of the times a complete line failing is a bad contact in one point and there is no power going to the line.
Of corse if you brake the screen you can end up with the same effect and this wont solve anything.
Votato
Annulla
Punteggio
3
8 Commenti
I have the same problem except mine is a red line and is on the right side of the screen.
da Michael Soudah
Mine is on a Windows and the clolour changes depending on what I'm doing on the screen. EXAMPLE: if I was using an application that was white in the area where the line is, the line would go white. And if it was on my black desktop, the line would go green and sometimes blue.
da X xteardamagex X
My thin vertical red line only appears on videos, like on YouTube, or like if Bing has a video background it shows up there also. Any ideas ?
da thealphapan
I the same problem but the color of the screen is full red how i can fix this? please help.
da Jayric Buella
I have that problem also but my line runs half way down the middle and it is a brown line. My tv is a Dynex
da Carol Stegemiller
Mostra altri 3 commenti
