Lo Huawei P8 Lite (Modello: ALE-L21), annunciato nell'aprile del 2015, punta sulla bellezza nella semplicità. Le sue fotocamere professionali permettono di scattare foto naturali e nitide anche in ambienti poco luminosi. La modalità beauty abbellisce il viso del proprietario in ogni selfie.
93 Domande Visualizza tutte
Dropped my phone in sea. help! CAN FIX IT AFTER 15 hours?
Hey guys yesterday my phone dropped in a gulf at midnight...if I swim at the morning and I can take it. It is 1.40 m from the ground
Update (07/12/2018)
I disassembled all in the phone expect the lcd and ear vibrator. . I have to roll it off completely or I can drop it with the pieces in the liquid you told me about.
And correct I am from Greece..also The battery is for rubbish now
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
If you're in Greece as your name hints to, it's just a pleasant swim right now, pretty hot here in the Med ;)
Nobody knows what happens to a submerged phone, but if you fish it out don't try to turn it on and don't put it into rice. Remove the logic board following the guide, put it into Isopropyl alcohol and let it soak there for an hour, then remove it and brush it with a soft toothbrush and let it dry for a day. Meantime buy a new battery and then try your luck, reassemble everything and hope for the best.
Sostituzione scheda madre Huawei P8 Lite
Punteggio 3
Aggiungi la tua risposta
Thanasis Katsoydas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 27
