Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3756 Domande Visualizza tutte
iPhone 5S stuck in bootloop with occasional red screen
Hi all,
I've been having issues with my 5S over the past few weeks. Started two few weeks back after I dropped it and the screen cracked slightly. A few days after, I had an issue where the phone stopped recognizing the SIM card (constantly said "Searching..."), but that was fixed with a software update. A few days after that, my phone started restarting intermittently, with erratic battery percentage readouts- sometimes it'd drop to low battery mode and need to be plugged in before it could turn back on, after which the percentage would jump back to ~60%. Never had it shutoff or get erratic percentages when on the charger, even if charging. The battery life has been poor for the past few months, so I chalked it up to early symptoms of battery failure and figured it'd be ok as long as I had a charger nearby.
Woke up this morning to the phone in a bootloop with the Apple logo. Turns on for ~10s, off for ~2s, repeat. I only get activity from the phone if it's plugged into an outlet. If I plug it into a computer, I don't see any activity from the phone or Win Explorer/iTunes unless I put it into DFU mode. Sometimes the phone will flash the red screen before shutting off, which I've read points toward prox sensor failure; sometimes it flashes the low battery screen before the Apple logo. Suspecting an issue with either of the two, but the intermittency of both makes me unsure.
I've tried swapping cables and a few hard resets with no avail, so I brought it to the local phone repair store. Their diagnostics found no hardware failure, and had no luck exiting the bootloop after power flushing (with the current battery and a replacement), and after testing with a new screen + digitizer.
At this point, I'm looking to see if I can get my 5S into a suitable state where I can back it up to iTunes again. Last backup was 10 days ago so it's not critical, but it would be nice to get that last bit of content. Not sure what steps to take next; hoping to avoid restoring/overwriting anything on the phone, and that maybe it's a corroded/faulty connection/component that can be fixed.
Thanks!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
All this does points to either a faulty battery or board issue. Hopefully just the battery, but these boards are failing at an alarming rate for the iphone 5s due to it's age. Especially after a drop.
I would have a shop plug in a new battery just to test. Should be free to diagnose if they're one of the honest ones, or a small fee from the major brands. If that doesn't help, you likely have a cracked solder ball caused from the drop that's making the phone act up.
Punteggio 1
Commenti:
Thanks for the response. The shop I brought it to said they tested it with a new battery but had no luck with that. I'm suspecting it might be a solder issue on the logic board- earlier today it was bootlooping without a charger until the battery died (hasn't bootlooped w/o a charger since), unless there's a point of failure on the battery connection. Is there something I should look for inside the phone, i.e: corroded/dusty connectors?
da
your front camera flex is faulty that is shorting the phone and change with original part and do software update thats all you need to do
da
That's what I was wondering at first, but the shop I took it to for diagnostics said they tried with a new screen (which I'm assuming contains the flex cable), unless they did something wrong during that test
da
Aggiungi la tua risposta
Dan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 35
Tutti i Tempi: 3,294
