Salta al contenuto principale
Guide e supporto per varie marche e tipologie di televisioni (TV).
9023 Domande Visualizza tutte
LCD Panel Pinout? Possibly
Does anyone have the pinout for the two flex cables/ribbons going from board to LCD display panel in an EMERSON LC195EMX 15" LCD TELVISION ?
...Im reffering to CN201 and CN3902 and Im trying to match up the pinouts to the LG lcd panel shown
Questa è una buona domanda?
Punteggio 0
1 Commento
@bbop676 just out of curiosity the Emerson LC195EMX is a 19-inch television why would you try a 15" display panel?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@bbop676
this is actually a Funai manufactured TV rebranded to Emerson. It will help to see your board itself so that we know which version etc. your board is. Post some good pictures of your board and mark what you are looking at. Use this guide Aggiungere immagini ad una domanda for that. You may also enlighten us what you are trying to fix or accomplish with a pinout. the only thing I can see right now is that you are looking at connector CN201 and CN301
Update (06/25/2018)
@bbop676 here is the pinout for CN3902 and CN201
Here is the connector for your panel
It’ll be a chore to come up with an interface…..not impossible but definitely not easy.
Punteggio 2
5 Commenti:
Thank you very much.. I did as you requested and added some photos and a brief explination
da
CN 201 and CN 3902 go to lcd display
da
I found a data sheet for board but the labels don't match whats on the lcd panel Im trying to incorporate
da
I may be grasping at straws here but I thought I'd ask
da
So you are trying to replace the original panel with the LG LM150X1? you are trying to use your existing boards with a different panel?
da
Aggiungi la tua risposta
G G sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,173
