Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
828 Domande Visualizza tutte
MacBook Pro is not BOOTING using ALT and/or to Recovery Mode
I have a MBP 2011 from a customer and I am trying to reinstall the system however trying to use ALT to select the PEN DRIVE with macOS installation is not working. The CMD + R is not working too.
I already tried reseting the SMC and it didn´t help at all. However I tried resetting PRAM and it doesnt work out.
What can I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
You mean Option Key don’t you?
Reference: Mac startup key combinations
Command + ‘‘R’’ may not work if the drive is not prepped (new drive). The newer firmware will automatically jump to internet recovery when you press Command + ‘‘R’’ so you will need a network connection to the internet via Ethernet or WiFi.
Did you replace the HD SATA cable yet? This is a common issue in this series.
Punteggio 1
Commenti:
Yes I mean ALT/OPTION.
I installed new drive tons of times and NEVER "prepped" the new drive. What should I do if OPTION and CMD+R both are not working?
I didn´t replaced the HD SATA. However I think this is not the case. Cause it came with a QUESTION MARK problem. and I just plugged the new HDD and it instantly showed the Apple Logo, however didnt go through the installation as I said earlier.
Att.
da
Does it boot up with an external drive when you've disconnected the internal?
da
Aggiungi la tua risposta
Angelo Recaman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 207
