How can I fix a front passenger side window that won’t go up on a Merc
The front th window on my 1985 Mercedes 300 TD won’t go up. How do I get it to go back up?
Questa è una buona domanda?
This should be the W123 model.
Looks like this model had both electric windows and handles. If electric, the first thing I would replace is the switch:
https://www.switchdoctor.net/mercedes-be...
Here’s how to get into the door panel if needed.:
Disassembling Mercedes W123 Door Panel
How to fix Mercedes W123 "screw open" style window regulator
Guida
Difficoltà:
Facile
5 minutes
Guida
Difficoltà:
Facile
10 minutes
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 64
1 Commento
Either there's a a leak in the vacuum line, or the switch needs to be replaced. Most likely ? The electrical switch on the center console. Twenty minute fix.
da M. Kohut
