Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4919 Domande Visualizza tutte
Why can't I unlock my sim
i can't click on the "unlock" (or the "ok" for that matter) button when the "SIM locked" appears
theres nothing wrong with the screen
it ran out of battery and when it turned on i couldnt do it anymore
I've tried resetting it and hard reset AND I've already tried to remove and get back the sim slot
+ when i did remove the slot it shows up the "no sim card" message and I could not click on the "ok" option either
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hmm thats really wierd make sure your screen is fully seated again, or try reinstalling ios to your phone if this doesnts help try going to the apple store where they csn scan your device
Punteggio 0
Commenti:
I recently did a screen replacement but I've turned off and on my phone multiples times after that and they all worked fine. I have also resetted completely the device, the problem remains
da
Then i would highly recommend taking it to your local apple store to get more info on your situation
da
that's what I'll most likely do, however I've gotten it to work by going into settings>phone>SIM pin and disabling it
da
yah thats so weird! Apple will perform a full scan for free then you can pinpoint the issue and we can go from there
da
Aggiungi la tua risposta
Inês Almeida sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 374
