Salta al contenuto principale
Repair guides and support information for televisions manufactured by RCA.
139 Domande Visualizza tutte
TV defaults to Analog
I have an RCA TV, model number 27V414T. It is an analog and digital TV - it came out right before everything switched to digital.
The problem is, it defaults to analog; and the only way to switch between analog and digital is with the remote. But the remote is broken.
I programmed a generic remote, so I can operate the TV that way, but it won't switch between digital and analog.
Is there a way to get it to default to digital, or am I stuck buying another remote?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I found the answer. I go into the TVs menu, and I choose to scan the channels. Right before the scan is done, it asks me whether it is digital or analog, and antenna or cable. I select digital and antenna, then exit the menu. Problem solved!
Punteggio 1
Aggiungi la tua risposta
MrJimPhelps sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,164
