Can I upgrade iMac (Late 2015) fusion drive to SSD?
Hello I was wondering if iMac (Retina 5K, 27-inch, Late 2015) was compatible to have the fusion drive upgraded to SSD? Specifically the Samsung 860 PRO 1TB 2.5 Inch SATA III Internal SSD. Will it fit and work? Do I have to take both drives out (both parts of the fusion drive) or can I leave one in? Apparently I need to buy an In-line Digital Thermal Sensor Cable and a 2.5" to 3.5" hard drive bracket as well? Or is there another SSD I can buy that won't require those?
Questa è una buona domanda?
1 Commento
To clarify things you damaged the PCIe slot hardware. So you would need to find someone who could fix the logic board or replace it.
da Dan
