Salta al contenuto principale
Released in May 2015 with a model number of CMP773 and a 9 inch screen.
1 Domande Visualizza tutte
Why won't my tablet turn on after I replaced the screen it was working
My daughter cracked the screen. I replaced it. It was working I tried some apps it was charging then my daughter got on it and it was at 12% and still on charger it went off and won't come back on it does not even show a battery symbol when charging.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@kastall you’ll have to recheck your work and see if the ribbon cables are still connected etc. There is always the possibility that the replacement LCD has failed. Also, if you have a USB AMMETER see if the tablet actually charges by pulling some amps. That would give you a pretty good indication that it is just the display that is not working.
Punteggio 0
Aggiungi la tua risposta
Karen Wolfe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 70
