Salta al contenuto principale
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
412 Domande Visualizza tutte
My 3ds x isn't charging
So I don't have a back plate on my 3ds x and so the battery is taped on to the ds's back but it still won't charge but it will when I move it a little but then it will immediately stop charging and turn off,is there a good reason why
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
The reason why it is having trouble charging is because that back plate is missing. Even if you have it taped on, the connection still may be loose. It also is more susceptible to shorting out due to poor connections. I would recommend looking into seeing if you can find a replacement black plate!
Punteggio 1
Aggiungi la tua risposta
Isaiah r sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 119
