Salta al contenuto principale
Rockchip Quad-Core RK3288C Processor, 11.6" 16:9 HD (1366x768), 16GB eMMC, Integrated Rockchip® Mali T764, LPDDR3 MHz SDRAM, OnBoard Memory 2 GB / 4 GB
18 Domande Visualizza tutte
I'm not sure witch one I have of the asus
How do I know witch asus I have to get a new screen for it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Hi Chase,
You can flip your Chromebook over and look for the model number under the barcode. For example, in this picture the model number is C201PA.
Punteggio 0
What is your model number? You need that in order to get the correct part.
If it is "C100PA", then ifixit has a display assembly for your computer:
ASUS Chromebook C100PA Display Assembly
Immagine Replace a display screen compatible with the C100PA model ASUS Chromebook. Includes the LCD, case, display cable, hinges, and Wi-Fi antenna.
Prodotto
$74.99
Punteggio 0
Aggiungi la tua risposta
Chase davis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 28
Tutti i Tempi: 351
