Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modelli 1660, 1774 e A1785. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
1364 Domande Visualizza tutte
Does "Tri-point Y000 Screwdriver Bit / New" fit other driver body?
Hi Experts,
I am planning to buy the "Tri-point Y000 Screwdriver Bit / New" to repair my iPhone 7plus. I would like to know whether this will fit in the standard precision screw driver body. I have multiple sets with me, all have the screw driver body has the same screw duct.
If it fits, then i can save a couple of dollars by not buying the entire set.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
If you have multiple kits lying around then this would most likely fit one of them... Most tools use the same design bits so you should be good!
Hope this helps and be sure to leave a comment if you have more questions!
Punteggio 2
2 Commenti:
Measure the shank of your bits so you know what your handle supports. Then review the IFIXIT listing it will tell you the shank size of the bits
da
Thanks Corey Meyer .
Will try my luck.
da
Aggiungi la tua risposta
Anupam sekhar G sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 406
