Salta al contenuto principale
Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
118 Domande Visualizza tutte
My Tablet is blinking when not charging or under 16%
My Samsung Galaxy Tab A is blinking. And it only happens when NOT charging or under 16% battery also it sometimes just shuts off by it self. I heard about fixes for "My tablet is not charging", but for me it's charging perfectly it's just blinking. Is there any fix or should i just get a new one.
Questa è una buona domanda?
Punteggio 1
1 Commento
My Cabana image picture tab 9” flickering while charging and does not switch on. I don’t no if the phone is fully charge. Android 8
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
This issue is usually caused by a physically damaged / worn charging port or the battery itself.
Charging port requires soldering so for that one you will need to take it to a repair shop that does Samsung Tablets.
For the battery it is user replaceable and fairly cheap to do. $15.
Here are link to parts and guide from iFixit:
Sostituzione Batteria (tipo A) Samsung Galaxy Tab
Samsung Galaxy Tab A 8.0 Battery
A red blinking notification LED light at the top left only when charging usually means that the device thinks that the battery temperature is too low.
This is usually a fault caused by a component like a thermistor (temperature sensor) in the charging circuit sometimes from liquid damage or damage on the charging port itself.
But I don't think that is the case as it would usually say 'Battery temperature too low. Charging paused' and the device would actually stop charging with a blinking battery icon.
Does it charge fine while it's turned off? anyway it's probably just the battery in your case.
Immagine Samsung Galaxy Tab A 8.0 Battery
Prodotto
$16.99
Punteggio 1
It seems to be problem woth battery replacing battery would help and if not then please check by testing new screen on it.. but most probably its battery
Punteggio 1
Aggiungi la tua risposta
David Raidd sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 49
Tutti i Tempi: 10,352
