Widows 7 is supported but you require the 32-bit version on your older Core2Duo CPU as your system is only 32-bit clean.
"What are the minimum hardware requirements for Windows 7?
The minimum requirements for Windows 7 are modest by today's standards:
- 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
- 1 GB RAM (32-bit) or 2 GB RAM (64-bit)
- 16 GB available disk space (32-bit) or 20 GB (64-bit) -- just for the OS, not applications or data files
- DirectX 9 graphics processor with Windows Display Driver Model (WDDM) 1.0 or higher
- Internet access
As with any Windows-based OS, a faster processor, more RAM and ample free hard drive space generally mean a better computing experience. RAM is especially important. For example, upgrading the RAM from 1 GB to 2 GB on a 32-bit system should give the end user a dramatic increase in responsiveness and apparent speed.
Microsoft has an Upgrade Advisor tool to assess whether a system is prepared for a Windows 7 installation. You can obtain the Upgrade Advisor from the Microsoft Download Center, or visit the Windows 7 Upgrade Advisor Web page.
For best results, match a computer's processor to the OS. A 32-bit computer should run a 32-bit OS, and it can't run a 64-bit OS. However, you can run either OS on a 64-bit computer. If your 64-bit computer has 4 GB or more of RAM, and doesn't run older, specialized 32-bit software or drivers, go with the 64-bit OS to get the best performance."
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
