The screen flickers, whites out and produces lines.
Macbook core duo A1181
Hello, my MacBook's screen flickers, whites out and produces horizontal lines. When I press on the left side of the display or press it from both sides, it often corrects it's self. I notice that it does not work with an external monitor either.
Questa è una buona domanda?
6 Commenti
What happens with the external monitor?
da mayer
On the attached screen does it grow worse or stabilize with running time? Does the system freeze or shut down? When you are pressing on the display is it towards the top?
da ABCellars
Actually, the external monitor is working after all. I just booted up the computer with the external attached and everything is working except the Laptop screen.
da Michael Perrick
The attached screen gets worse regardless of running time. The computer stays on and functions normally. I need to press the screen on the left side towards the middle.
da Michael Perrick
The external monitor working isolates the problem to the display parts. That's good! Now to figure out if it's the cables inverter or LCD. Does anything change when you move the display up and down? Has anyone ever worked internally on your Book?
da mayer
Mostra 1 altro commento
