Salta al contenuto principale
Il Galaxy S7 Edge è la variante schermo curvo del telefono top del 2016 di Samsung, il Galaxy S7. Annunciato a febbraio 2016 e lanciato l'11 marzo. Modello SM-G935.
368 Domande Visualizza tutte
S7 Edge battery won't charge to 100 percent.
I have an s7 edge and the phone won't charge to 100 percent and the battery drains fast. All this started happening when I swapped batteries. My last battery was shot that's why I changed it.
Questa è una buona domanda?
Punteggio 1
1 Commento:
I have same problem phone not charging stop at 75%.So far my battery is build one. Pls.suggest me.
da
Aggiungi un commento
1 Risposta
Your charger port could be bad. That would effect your battery draining fast and not achieving 100% charge. If it is not the charger port, it is the Motherboard.
Punteggio 0
6 Commenti:
Thank you for that. I might try a wireless charger next because I've factory reset the phone twice. I did finally fix the drain issue, but I still can't figure out why it won't charge to 100%. I will continue on my quest, lol.
da
Yes, usually that is my quick/cheap fix for newer Samsung’s with charge issues. Purchasing a wireless charger is much cheaper than the other options. Just a little inconvenient.
da
Mine won't change past 20% and it's acting all ceazy
da
So you might be experiencing a bad battery. Have you replaced that?
da
20 percent is terrible!
da
Mostra 1 altro commento
Aggiungi la tua risposta
Moses sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,742
