Can´t click with my Roccat Kone XTD
If I turn on my Roccat Kone XTD and I want to use it, my mouse doesn´t left- and rightclick. I don´t know what to do please help.
Questa è una buona domanda?
When the mouse is older than 5 Years the buttons might be broken, but you wrote that with a hotkey they work ?
So you should remove the driver and also delete the profiles etc. by deleting all folders and files from roccat on your pc. AppData, Documents, Common Files etc. …
Than restart your pc and install latest driver from the official roccat website.
Or you try to use the “Reset” Options inside Roccat Software (Driver Reset)
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,945
@blsquad can the mouse cursor move ???
da Augustine
Yes with the curser is everything ok. And if I use a hotkey on my mouse I can right click, but not left click.
da BlSquad
@augustine Yes with the curser is everything ok. And if I use a hotkey on my mouse I can right click, but not left click.
da BlSquad
Hi @blsquad , If you use your mouse at another PC, does left the left click issues still persists?
da Augustine
Have you installed the according drivers for the mouse?
da Niels
